Noisy Toilet
8 Dec 2016
Can anyone please help troubleshoot a noisy toilet? It's a concealed cistern and the noise happens roughly every half hour or so. I'll try to upload a short video clip so you can see (hear) what I'm talking about. Thanks in advance.
Sounds like there is a loss of water somewhere and it's having to top up the cistern every half hour or so.
I can't tell much from the pictures but the water loss will usually either be down the pan or out of the overflow pipework.
Either the float needs adjustment so the water is below the overflow level or the innards are old and leaky and may need replacing.
Thanks for your reply. I'll do a little more investigation and see what I can find.
+1
Judging by the mildew that can be seen on the inside rear of the system, it could well be that the flush valve is not seating in the outlet properly and is letting by. Can you see very slight trickle into the pan all the time?
