Evening all. A little advice if you can help me.
We have a little cottage fed from a private water supply (well/spring). I use a lift pump to feed a coffin tank in the loft. The coffin tank then gravity feeds the hot and cold water system plus a central heating header tank in the usual way.
We are rebuilding after a fire and re-using / extending the old water system. My question relates to the hot water vent pipe from the tank which is at first floor.
The coffin tank contains our clean and treated water supply. I'm not sure about the hot water vent pipe being returned to the tank. Are there any other options? I don't want to return any overflow to the cold water supply. Could I put a new external vent/discharge pipe in instead? I'm assuming it is only there for failures/emergency and won't actually create a flow?
Many thanks
Chris
Many thanks
Chris
