Non-Plumber - needs help!
10 Apr 2009
Belfast
Mate returning from hospital this week has asked me to get the house ready for him, he's recently had an extension built - and the radiators are only luke warm from the multi-fuel stove - here's the set up.
10 Rads
LARGE multifuel stove with back boiler (In new extension)
Oil Boiler
Open fire with back boiler (Original cottage)
apprx 50 or 60 litre factory foam fitted cyliner - with 3 COILS???
I've been burining large fires in stove this past couple of days (Just want it to work without using oil) - Rads heat to luke warm only.
As I say I'm not a plumber - but surely this cylinder (1m high) with three coils isn't adequate? - but is that the problem?
Check the pump and have you got any hot water?
Thanks for comming back to me Shawd -
The pump is set to come on by thermostat at 50 degrees - just checked there and the temp was around 45 (I adjusted the thermo to 45) the water from the taps is not hot - just warm
END OF THE DAY , WATER AND HEATING WILL ONLY GET HOT IF YOU HAVE A GOOD ROARING FIRE PRESENT AT THE BOILER AND ALSO MAKE SURE YOU HAVE WATER IN HEADER TANK ,THE HEAT HAS TO BE SOMEWHERE :confused:
ALSO OPEN THE AIR INTAKE AT THE BOTTOM OF THE STOVE
