I am about to put a water softener in and see it needs two 'outlets' - one for the drain when regenerating and one for the overflow from the brine tank in case there is ever a problem.
The instructions call for the overflow to go out through an outside wall and oveflow to atmosphere, but I can't as I don't have an outside wall to go through.
I do have the 40mm wast pipe the water softener drain is going into though (together with a washing machine and basin) and the softener overflow is above the level of the P trap. Consequently I was thinking of hooking the overflow pipe up to a redundant washing machine connection on the P trap so that it overflowed down the foul drain in the event of a malfunction....
Then I got to thinking... if the P trap blocked or the drains backed up, foul water might run back along the overflow pipe and contaminate the brine tank on the softener... which wouldn't be pleasant!
So is there any sort of one way valve that has minimal resistance to allow the free flow of water from the overflow but stop any potential backflow? Something I could fit in line? I checked an ordinary 15mm check valve and the resistance to flow is too high for the atmospheric flow out of the brine tank to overcome.
