I have a bath shower mixer tap which has been installed for some time and is fed from Mains cold and Gravity hot. As this is unbalnced it meant it was difficult to get an even temperature when using the shower as any minor adjust meant the temperature would go from warm to either scolding or freezing. As the bathroom was getting a bit of a tidy up I decided to try and get the shower working better. After looking into many options I opted to install a Pressure Equalising Valve. Fitting the PEV has fixed the shower temperature issues we were having but I have quickly relised that at the PEV the mains cold is being backfed into the hot supply and leaving us with no hot water.
My understanding is to get round this I need to put a Non Return Valve (Check Valve) on the Hot supply feeding the PEV to stop the cold being backfed to the HW Cylinder. Is this correct and would I also need to put a Non Return Valve onto the Cold supply feeding the PEV too?
