I have a Grohe combined bath filler and waste. The waste pipe is a ridge L shaped (32mm outside / 28mm inside), which I cannot fit as my bath has a metal frame which is in the way (just where the bend is).
I was thinking of using a flex pipe but can find the correct size anywhere. I have even call Grohe but they can't help. I don't want to cut the metal bath frame.
Do you know where I could get the correct size pipe & fitting.
