Non standard soil pipe
1 Feb 2014
Middlesbrough
I have moved into a new house recently and yesterday I noticed water on the bathroom floor. On closer inspection I noticed it was a leak from the toilet waste pipe connector. It looks like a bad job. The pan outlet is 80mm, but the soil pipe is also 80mm and not a standard 110mm. Whoever fitted it has tried to force a 80mm to 110mm pipe connector on and damaged it. I have tried a search online to find a 80mm to 80mm connector but no luck. Any quick fixes?
Standard connections unless you live in Spain, seal has gone on your pan connector,buy a new one,many options available. Never come across a non standard soil pipe unless you have en suite,sometimes 3 inch leading to 4 inch.
Looked for options, the standard seems to be 110mm pipe
The connector won't fit inside 80mm pipe
Might be a tad difficult sourcing a 3" pan connector. :p
So long as the pan outlet is not greater than 80mm you can have a stack of minimum 75mm. Providing no other WC is connected.
Yeah, pasting is great fella having a clue is different. :rolleyes:
We used 3" pan connectors (straight adapters) (over 200) when refurbing a block of flats in Newcastle, all toilets went into 3" cast pipe. Multikwik make them.
No,you didn`t,no such thing, you used a converter to plumb into cast pipe, ;)
Nobody makes toilets with 3 inch outlet, Simples. ;)
We used 3" pan connectors..........
Multikwik No10 is for 41/2"/108-114mm pan spigots. OP states his spigot is 80mm. As previous, Mk do not do 3"/80mm both ends.
The only way round it (using Multikwiks) would be:
No5 (for small spigot)
Multilink
No10 (for small pipe)
