I should start by saying I'm a plumber and normally go out of my way to avoid anything to do with wiring, however my electrician is on holiday all week and I have promised to have all chasing and cables run ready for him to connect when he returns. I realise I should've asked him for a wiring diagram and he probably assumed I knew what to do, but it turns out I don't hence here I am!
The project is my own bathroom which has taken me nearly 6 months (near completion) since I only get the odd free day to work on it here and there, therefore any advice which prevents it dragging on would be very much appreciated. Really what I need is a step by step description of which cables to run from what and to what?
I'm fitting an in-line ceiling extractor fan in the loft space above the shower (which doesn't have a timer.)
The wall outside the bathroom door is block work in which I already have a chase from skirting to ceiling (for underfloor heat mat cables to stat, then 2.5mm T&E which runs up to and through loft space and back down to consumer unit in kitchen). The chase is large enough for additional cables I just need to know how many more boxes to cut in and where etc.
As I would rather not have a pull cord inside the bathroom is it possible to use a fan isolator switch outside?
Do I need an additional fused spur? Does this need mains power?
Also do I need a fused spur before the u/f heating stat?
Which size cable to I need for each step?
Any help very much appreciated, many thanks.
