Its either water based gloss or satin...been using it on and off for years, its not been accepted by the trade complelty yet though and still has a long way to go technology wise....
PRO'S....quick drying (about 20 mins)....non yellowing.....low odour.....'elastic' paint film....so its good for outsides....keeps its sheen level longer than oil based outside..reasonably easy to apply (if you can paint quick)
CONS...not as shiney as oil based (although dulux aquatec comes close) you have to paint fast....the 'edge' goes off quickly...tricky for broad areas..more expensive than oil based....takes ages to dry if the weathers cold....
Dont bother with the home brand stuff from the DIY stores...most of their stuff is rubbish.
no not that i know of, they do eggshell satin wood aswell which i think is better its got a slight more sheen and can be washed down with soapy water makes it more durable.
for some extra info, for people who shop at B&Q. paints are usually cheaper at focus especially Dulux paints.
i saved £5 on satin wood!! Bargain....
Zampa you know cutting in on wall, would you say role straight away or wait for cutting to dry??
i normally role straight away and into it to blend it in, but just wanted your advice on it.
If im using vinyl matt I normally cut the whole room in then roll it, it saves time keep picking things up and putting them down again,
I would recommend cutting in one wall at a time and the rolling it straight away, when you do the tops and the bottom turn the roller and roll along the ceiling skirting line, getting and close to the ceiling and skirting as poss.
