I have an old bungalow with poor insulation. And a lot of external walls.
My existing 37kw W Bosch combi boiler has just failed on me. About 6 months before I was planning on replacing it...
I also have an old wood burner needs replacing too.
Is there a system I can get that will let me pipe in a back boiler from a wood burner to boost the heating and still be pressurised from the mains water?
(I have space for a tank if it needs one)
I don't use a lot of hot water but due to the house layout, I do use a lot of heating. I work from home most days and keep the work room warm with the wood burner but would like to spread that heat around a bit. I'd rather not use fans and ducting because they're noisy.
Because it's a bungalow, I don't really want a low pressure system because the pressure will be tiny. (Without spending loads of money on pumps)
