- Joined
- 24 Aug 2016
- Messages
- 2
- Reaction score
- 0
- Country
Hi, new to the forum here. I have a very fundamental question.
It's mainly about whether I should design my building using metric or imperial measurements. I can't work out if the wood I'm looking at is graded and sold in metric or imperial. You say 4x4 inches, for instance - and 50x50cm, etc - but is that wood actually cut on a machine using metric or imperial sizing?
For instance, when designing my 3D model in inches, I had my units set to CM. So: 1inch is 2.4cm. A 4" thickness works out to 10.16cm. I've just looked at some wood merchants online and they are doing all their thicknesses in metric. So now I'm not sure if I have to redesign everything to the nearest centimeters or what.
In other words, is it Imperial sized wood sold to the nearest centimeter or is it actually metric sized wood to begin with?
I don't know if there is some standard across the UK whether they use metric or imperial or whether it varies between companies.
Seems like a small detail to some but it matters to me because I need to pre-plan everything.
Thanks in advance and thanks for your patience.
