Not sure whether to pressurise central heating or not...
12 Oct 2009
Hertfordshire
I've moved into a new house with 21 radiators. I have literally spent days trying to balance up the radiators... I have used Fernox F5 to clean it all out... I've flushed it twice.
I think I'm getting somewhere balancing the rads turning the lock valves millimeters at a time but then next time the heating comes on half of them don't work again.
What are the down side of pressurising the system? Will this solve my troubles? Is this a good plan or a bad idea?
What happens when the pressure gets low as I'm sure it must do or does it sustain itself?
That actually makes sense. Godamnit... I don't think I will ever get this system balanced.... its blooming difficult.
A plumber came over and showed me how to do it but said I should do it myself as it will be expensive to have a plumber there for a day to balance it up.
Hello, I'm disappointed to wake up today with one radiator!! One measly radiator and its not even that hot.
We have a WSP ESE 125 three speed pump which is on full. It definitely works... and a Boulter Camray 3 which is quite a big oil boiler.
Unless you want the system tuned 100%, 2 or 3 hours should be enough to get all the rads working more or less the same.
