Hi can anyone help? We have an Aga cooker (gas) which provides cooking and hot water only. A separate combi boiler exists for the central heating. The cooker used to provide hot water for a lot of people but now for only two. We can also heat the water with an electric immersion switch. This was in place for during the summer months when the Aga was switched off it giving off too much heat in the kitchen. A separate gas hob dealt with cooking and the immersion switch for hot water.
There is a hot water tank very large which is fed by another tank in the loft which I presume feeds the cold water into the tank for heating. The water in this loft tank has become quite warm and I think the rise in temperature affected some of the seals hence a leak? I have been told that the problem is that not enough hot water is being drawn off now and that this loft tank is now acting as a radiator. Is this possible? Is it correct and if it is what remedy exists? As a layman I cannot see why "not using enough hat water' should be an issue. Any system I thought should be able to adjust for this!!!
