notched trowel size and type
I did. It says 6mm is standard for wall tiling however it makes no mention of wet areas. I've since found the bal manual which says use 10mm.
Thanks for your reply.
8 or 10mm notched will do that size off tile.
thank you.
No probs.... ;)
Remember always have the ribs off adhesive going across the wall not up the wall....
Tiles won't slip down as much...
You won't get to much adhesive coming thro between tiles....
Any water ingress won't run down behind the tiles as much,,..the ribs will slow it down and absorb it...lol...
Just follow mfr rec...regarding adhesive curing time and when to grout ect..
