If you are installing new cables across joists and the old cables are situated in notches, should you utilise these notches (with added protection) or should you drill new holes?
I ask the question because I was asked this question for my 16th edition exam and I said the latter (based on the assumption that the original notches may not be in the prescribed areas), apparantly I was wrong, as drilling new holes would weaken the support.
An electrician friend of mine insists that you should NEVER use notches regardless, and should always drill holes.
