I know its not best practice and maybe even bad practice but will the below be ok in an isolated instance.
8"x2" 1st floor joist spanning approximately 1.5m from a chimney breast to the front of the house. It runs parallel with the external side wall and i need to run a conduit down the centre of the wall and into the floor void. The wall sits on top of the joist so i would like to bring the conduit down onto the joist and then into the floor void at a 45 angle.
This will mean notching 30mm deep 60mm long through half of the joist at a 45 angle meaning the amount of material being removed is minimal.
Given the amount of material being cut out and the length of the span is this acceptable?
