Hey, Is notching through the central span of a joist totally against the rules etc. Also is the same for drilling holes as these don't weaken the joists as much.
Thanks if notching do people tend to do one notch and run the heating and hot and cold pipes in this or two separate notches so the heat from the heating pipes doesn't effect the cold water pipe?
I don't know how many pipes you are running, but I would just run them in the order that is most convenient for you. Just make sure you run them in the centre of the board leaving enough space either to side to re fix the board.
