I have placed my joists hangers on my new blockwork today. Because of doors still in place i have not been able to get a fully accurate level with the new extension floor and the current internal floor.
I wanted to be a little high so all i would need to do was notch the joists to get the correct level.
I think i will need to notch the joist about 50mm. Is there a limit to how much you can notch.
I have purposefully overspeed the joist size as i prefer to use a larger one as it gives more stability. I am using a 47 x 145mm joist at 450mm centres and the max span is 2.5m.
