- Joined
- 10 Nov 2020
- Messages
- 2
- Reaction score
- 0
- Country
Just been directed to this forum and looking for help / Ideas
We are building a timber frame 2 storey property that is just over 1 metre from our boundary. Building Control has rejected our wall make-up.
The timber frame has 70mm PIR in the frame with another 50 of PIR on the innerside of the frame, then followed by service batten and plasterboard.
To the other side of the frame is MultiPro XS, then battens and finally wood cladding.
The wood cladding is a planning requirement and there is no option to change this.
Due to being close to our boundary, BCO has asked for a certificate for fire test covering the overall wall solution for fire from inside and outside. This seems an impossible request as no manufacturer has conducted this test.
It is not clear if it is the PIR causing the problem or whatever solution is used a test is required, all we get is 'it does not meet building regs, we don't offer solutions' no help or guidance at all, so go away and find a solution.
This is the BCO's comment ' The importance of the system as a whole is to ensure it provides the required fire resistance in relation to parts B3 and B4 of the Building Regulations 2010.'
Has anyone else run into this problem and found a solution or has anyone else built close to a boundary and had a solution passed.
It would be great if a BCO or qualified person could explain how to resolve this.
Thank you in advance
Colin
Colin
