Hi-firstly, thanks for looking. Right, i'll attempt to describe the list of symptoms as accurately as I can:
I have a 7 year old Powermax Range 160 combi boiler. I moved into my house in 2007, and a neighbour warned of the problems she had with hers. She's been advised that it is not a boiler designed for hard water areas (which I live in), and due to this, has to have her system flushed annually. In 2007, we started losing hot water pressure, then temperature, unill we had virtually nothing. The central heating and cold water remained fine. I had BG out, who diagnosed a blocked plate heat exchanger, and put a new one in. I kept the old one in the hope of unblocking it using chemicals, so I could swap the 2 whenever one became blocked. The BG Engineer confirmed they had replaced the heat exchanger 2 years prior to this. One year passed, and we've lost just hot water now. The pressure is ok as is the central heating, but over the last 2 months it's got progressivley worse, up to now, where we have none at all.
I can't imagine the heat exchanger becoming blocked in 12 months, can anyone advise a possible cause/remedy? Apparently the only way to cure this problem permanently, is to either replace te boiler, or fit a water softener-both of which are to costly at the moment, as I have a young family.
Thanks again for looking, Olly.
