Correct me if I'm getting the terminology wrong.
I have a NTE5A BT master socket that has a single socket so I have to use a microfilter to plug in my phone and broadband router.
I would like to extend using a single cat5e to a faceplate with separate BT-jack socket for a phone and an RJ11 socket for my router.
I have seen a video on YouTube which shows that this can be done by using 4 of the cores in a cat5e cable to connect data and voice separately using 2 cores each.
In the video, data is connected to the A/B terminals and voice is connected to 2 & 5.
My problem is that my faceplate has a single socket and no A/B terminals for data.
Can I purchase a replacement master socket of VDSL faceplate that has the necessary filter for voice builtin or do I need BT to make changes at their end?
If I just need a replacement socket/faceplate I'd be grateful if you could provide enough of a description for me to find it online and wire it up correctly.
Many thanks
Many thanks
