Hello
I have a circuit of 2 x smoke alarms and 1 x heat alarm for which I want to remove the interconnecting wire. I beleive the interconnecting wire has been damaged as when all three alarms are connected they sound continously, but when I remove the first alarm in the circuit the other two do not sound. I have tried replacing the unit with a new one, but same issue.
Until such time as I can get someone in to replace i want the units to still operated but independently. As an experiment I disconnected the black interconnect wire in the alarm which directly connects to the upstairs lighting circuit (I beleive this is the first one in the circuit???) and that seemed to solve it. All alarms still detect as they should, but independently without them all going off.
Is it safe to remove the interconnect wire. From what i can find on this site the interconnect with is not mains volted, so I am guessing that by disconnecting the interconnect wire in each unit and covering in insulation tape this will solve the problem.
Many thanks
Billy
Many thanks
Billy
