Hi guys,
Having an intermittent (bloody annoying!!) fault with my oil fired burner.
19 times out of 20 burner starts hunky-dory without problem.
1 time out of 20 controller fires the spark down the electrodes, but the motor does not start ( & hence fuel pump et al ).
Problem started just recently after running out of fuel - hence I have cleaned the fuel filter, pump filter & nozzle.
The controller is a Satronic TF830.3 and I'm assuming the the problem is 'caused either by a faulty controller or by a faulty motor.
Just looking for some reassurance that I'm looking in the right place!?!?
As a seperate issue, what do you use as a thread sealant on oil filter fittings? I've been using PTFE tape but always seem to still get the odd drip ....
Thanks in advance.
Colin
Thanks in advance.
Colin
