Hello, do you know what size the o rings are, which are used to seal the bleed valve and blanking cap against a radiator or towel rail? Quite often when I take these off (eg to add inhibitor) they come off in bits.
I've found an o ring chart with a size 19 which is as follows. Does that sound right?
ID 20.3mm
OD 23.9mm
Diameter 1.8mm
Alternatively Ebay has 20mm x 2mm.
ID 20.3mm
OD 23.9mm
Diameter 1.8mm
