O/T plumbing job lot
21 Sep 2015
Wiltshire
WILTSHIRE £200 for the lot
3x flush handles
Pack of 2 jubilee clips
2x packs of 2 wars 15-1/2 inch flexis 30cm
Pack of 2 15mm-1/2 inch John guest speed fit flexis
2x 7inch rtd heatrae sadia thermostats
Trade fix filling loop
Sink combi waste
Bath combi waste
Bath cross top taps
Bath lever top taps
Basin lever top taps
2x sink lever top taps
Sink cross head type taps
Sink base type taps
Dudley turbo 88 syphon
Missing parts Dudley turbo 88 syphon ( fixing kit )
4 trade close coupling kit
Fluid master pro45b brass shank
3x fernox lsx
Centre brand webbed abrasive strips (10)
Plumbers tap repair kit ( holdtite ) x2
15mm brass stop cock
2x 15mm compression couplers
2x 15mm compression elbows
2x 15mm compression cap ends
2x 1 1/4 hush flow washers
3x 3/4-15mm lockshields
2x part 2 ballvalve a with float ( brass thread)
Ballvalve repair kit
3x 1/2 nylon washers
3x 1/2 fibre washers
Pack of 3/4 fibre washers
Pack of 1/2 sealing washers
Pack of 3/4 sealing washers
Pack of 2 x2 1/2 top hats
Pack of 1 1/4 ballvalve washers
3x Gas ptfe
Internal flush cone ( simpla 2 )
Pack of 10 Stanley blades ( faithful )
Professional silicone reseal kit ( brand new )
Pack of 3 flux brushes
New solvent weld (125ml)
2x 40mm streight compression couplers
Pack of 2 .. Plum pad
3x 785 Dow Corning white silicone
Pack of 75 sheets of cloth
2x 40mm compression elbows
Mcalpine streight flexi connector
Multikwik extension connector ( long)
Multikwik short streight pan connector
Rocol leak detection fluid
Pack of 10 1/2 poly washers
