Can anyone give advise on installing solid oak 20mm T&G (all-round)
flooring. I have a concrete floor (3 years old with DPM below it) which is 5" below the level of the oak floor. I had thought of installing batons or small joists directly to the concrete or batons to the concrete plus 20mm plywood onto the batons, then blind nailing the floor to the batons or the plywood with an expansion gap at the skirting boards. Should I fit a DPM between the plywood and the oak? I'm not keen on glueing the floor down because I don't think it will be able to move so easily as it expands and contracts. The concrete should be dry after 3 years, but there is a small amount of damp in the lower wall bricks at concrete level (wall has been damp-proofed, injected ) so there could be some moisture to think of. Realise this is a bit unusual and I might have asked some daft questions - first floor!
