Oak worktop
11 Feb 2013
Essex
Hi all
I am a diy'er
and fitted my oak worktop in my new kitchen at the weekend,
however i have not oiled it properly
it came with one coating pre-applied but i have fitted it without oiling the cutout areas and have not oiled the underside, it would be a huge job to remove the worktop as its all joint together in a U shape
so if i can access most of the underside but am un-able to access the sink cutout and a few other areas for oiling, is this a major?
thankyou for any help you can give
Why would you need to oil the underside?
The oil is to protect it from water spills, and i don't think you'll have many of those under there. Just oil the top!
most giudes i have read say every area of the worktop should be oiled in order to stop it bowing/ splitting
Never heard of that myself. I only oiled the top of my oak worktops and have had no problems in two years.
oh ok cheers thats good to know, as the last thing i want to do is take it all apart now its all fixed and level
I usually oil all round (mine had 5 coats all round before fitting). However, I would not expect problems with not oiling the underside but would be concerned if any showing end grain was not treated.(i.e. round the sink opening)
Worth checking out if the underside is oiled to 'balance' it out as far as moisture being drawn in. We do not sell solid wood, but I am sure my fitters have said you have to oil both sides...
