I currently have an open fire which i though had a 16" milner fireback.
I am looking into getting a wood burning stove fitted however, the quotes i had for knocking out the existing fireplace, making new and fitting the wood burner came to £2500 - £3000
Next i toyed with the idea of having an inset stove, which fits snug inside the chair brick ... but ... having measured up my opening it seems that perhaps mine is not a standard size
The measurement of the width of the back of the firebrick is 255mm however most of the inset stoves i have found (which fit a 'standard' 16") have this measurement at 270mm except two which are over £1000
my genius (or ridiculous) idea is to have a standard box stove in front of the opening (on the hearth) and run the flue pipe straight out the back of the stove and up into the chimney (no doubt with a register plate)
does anyone know if this can be done?
