obvious combi boiler question
7 Jun 2004
i cant find the water supply for the combi boiler and need to replace some taps. i have no ball stops on these pipes. can i shut down flow to the taps from the boiler itself?
Most combis have a quarter-turn valve on the cold supply, which is usually below / under the boiler, against the wall. Look for a 15mm pipe.
Of course, this will only turn off the supply to the Hot taps.
would that be the one with the yellow or blue lever? i assume blue?
