occasional heavy knocking
12 Nov 2008
Tyne and Wear
Thorn Appolo boiler system with cylinder and 3way valve. After Ch has been on for a while, occasionaly get heavy knocking when boiler fires up. Preliminary checks have found that this is caused by the pump not starting till the boiler has been firing for a while. Am I right in suspecting the 3 way valve?
pump should be wired through the boiler
if the boiler is firing ok but pumps not running
fault is prob in the boiler
which apollo is it :?:
Thanks for your interest. Boiler is 20 year old Apollo 30/50B. The problem is intermittent but alarmingly loud, it usualy occurs after the heating has been on for an hour or so. the stat will demand heat, the boiler will fire but the pump will not, boiler will vent to expansion tank (hammering) then things will return to normal for a while
right try i assume you know how to use it ;)
try belling the stats first
intermittent is a PITA BTW
dunno why but something is picking at me pump overrun stat :idea:
if you want the mi's put a e mail in your profile
or try partsarena
Thanks a bunch for everything, sorry about the rule thing. Will commence fixing tomorrow. So its goodnight from my home town Washington (the original) UK
Good fortune Bill
