Ive got a typical 2 way switched system for the lighting in my hall, i'd like to add a occupancy detector to this, i've got a CP Electronics EBDSPIR, IS there any reason why the switched live from this and the switched live from the 2 way switches can't be in parallel, so either the switches or the detector will turn on the lights?
EDIT - Just found out its possible to wire more than one detector in parallel in the same fashion as detailed above, so it should be ok
