ocean alpha 240p
2 Mar 2006
Kent
hi have a leak from diaphram pin to micro switches, is it just diaphram to replace.
i removed micro switches (1 screw ) there is no nut to tighten or undo where pin comes out
No. It would be a good idea to change the diaphragm if it's a few years old, but the gland seal on the end (14ish mm nut) is a separate part. The pin can wear too.
Nut - six sided thing marked green, round leak, marked red
ChrisR the pic is rite except no nut hence leak and can i get one
