Odd question: how to glue 2 plastic things together
OM2
18 Jan 2007
OK... I have an odd question... that I'm sure someone here will be able to answer!
I have a camera, the door for the memory card has broken - there's about 25% of it left
The camera still works perfectly fine - but I have to hold the door in place with my finger
This is a pain!
The door still needs to be kept accebile and be opened to get the memory card out - so I can't just super glue it in place!
So... I hit on the idea of using a small piece of velcro that would sit over and keep it closed - with another piece at the other end for it to hook onto
But... how do I glue the velcro on? I need something that will allow the strap to me moved around a little - but still be strong enough to stay in place when pulled
See the image below for the actual item:
ANY help would be great!
OM
Just my opinion but I don't think this exercise would be particularly successful long term, so why not try to find a new door for your camera?
If you can't find what you need on the web I'm sure the camera manufacturer would come up with something.
John :)
John :)
john thanks for the reply
i can pickup one of these as a faulty unit on ebay
just looking at it: i'm not sure if the replacement would be straight forward
the working version of this particular model can reach £70 - £80 on ebay for some reason - i only bought it for just over £100
i love the camera and it's a lot better than others i've tried - so i'm a little desperate to keep on using it!
one possible solution i've thought if is to use duck tape - but again, i'm stuck with the problem of making one of the ends stick permanently!
thanks for the reply all the same
Tape it shut and use usb cable to access memory card?
yeah... i thought of that
not sure i want to do that though
using a memory card reader to take photos off is much more conveinient
If you try to fix it...then it will not remain for too long so its better not to try this.
