Hi Guys, looking for advice on a softwood door, half glazed/half panel, ie. 2XG/2XGG
The personal door in our garage has rotted after 25 years. I need a new one. The size of the door is 798mm x 1975mm. Jewsons were showing one Exterior 2XG Softwood Dowel & Glued Panel Door 807 x 2000, but apparently this is now obsolete and they can no longer supply.
Standard door sizes are 838 x 1981 and 813 x 2032 both of which would need quite a bit cut off. I seem to remember reading somewhere that you shouldn't cut more than 10mm off each side? Is that correct? How much can I safely cut from a door like this without affecting its build/strength? If I went for the 813 width one I would have to cut 57mm off the height.
The other option is a "made to size" order which is going to be a lot more expensive, or does anyone know of anywhere I can get a door 807 x 2000 or there abouts?
Thanks for any help,
