Hi folks,
This should be a simple job but I can't find the right sized tap washer anywhere!
It's for a mixer tap (3 pipe type) - the washer looks fairly standard albeit on the small side. Flat black rubber washer with hole in the middle - outer diameter 12.5mm, hole diameter of 4mm and just over 3mm thick. It's probably imperial - 1/2" outside diameter x 5/32" hole x 1/8" thick.
Where can I buy a washer of this size from?
Bonus question - why is it that 3/8" washers aren't 3/8" no matter which way they are measured?
