Odyssey x backlight
20 Oct 2010
Lanarkshire
Hi anyone tell me what lights should be on the above connected to an elite 24, I have the alternating leds and that appears all, no backlight, is there anyway to test/set up this?
Backlight if you have a backlight module.
It wires into the power terminals alongside the bell connections.
At default it’s on 24 7
Thanks will double check tonight and can I confirm the backlight is the row of white leds as I am sure that I had these on when I tested the unit when I rigged it up to the 12v on the panel before fitting
yes a row of leds built into the unit where it flips down so is in front of the main pcb
Thanks so they were working when I tested will wait till dark and see if I missed them, then have a chat with the engineer that fitted the box
Probably one of the wires is not in correctly as they just double up on the 12v bell supply
Can I ask the installers would you have a backlight or not, I assume it’s on all the time?
Thanks will get a graphics insert ordered and call the installer to see if he can check the wiring and fit the graphics at the same time
I suppose you could switch it on via timers at a certain time if you had a spare core at the bell box ….pyronix delta bell has a photocell built in to switch it on / off
