I would be really grateful for some advice please....
I live in a new build (2006) flat which has peak electricity (available 24 hours) and off peak electricity (available during the night). The appliances which run off the off-peak power have two sockets, and the off peak socket is switched to 'on' all the time. These sockets have a red indicator light on them and the light is off during the day and comes on at night, along with the appliance itself.
Recently, the off-peak supply has developed a fault - the red indicator light still comes on but the appliances all remain off. It happened to all 3 appliances on the same day so that excludes a fault with them. The fuses are still OK. We can still get power during the night from the peak circuit.
I understood that the two sockets represent two separate circuits because a note on the fuse box says '2 SUPPLIES ENTER THIS UNIT ISOLATE BOTH BEFORE ENTERING'.
I contacted an electrician, who said that the fault must be outside my flat and that I would need to contact my supplier. My supplier can't seem to understand the problem and says that if there was a fault with my meter then I would have no power at all. When I try to explain that I have two separate circuits (because I thought I do - am I wrong?) they say I can't have because I only have one meter.
I would be so grateful if someone could explain to me what I need to say to them about what has caused this! Thank you
Philippa
Philippa
