Hello
I am installing a consumer unit, circuits and storage heaters on friday for an off peak supply. A dual tariff metre and tails will be there.
The size, length and material of the tails will be the same as the existing cu give or take a few cm's. So in order not to have to do the Ze and pfc at an unsociable hour, would it be reasonable and correct to take the Ze and pfc reading from the existing cu and use that as a Ze for the new cu figure. I can obviously add my R1 + R2 to get ZS. Luckily the new circuits will be run in such a method that RCD protection is not required.
Regards
Regards
