I'm pretty new here, and seen as there doesn't seem to be anywhere specific for introducing yourself here seems as good a place as any. I'm an electrical/electronic engineer by trade, although willing to give almost any DIY work a go.
Biggest DIY project to date has been the conversion of an old room at the back of the garage into an office, pictures below...
The room used to have a dividing wall which went straight down the centre of the window. The front half had a slightly worse for wear laminate floor and was the walls had been cladded with chipboard and then painted, the colours suggested it might have been a children's play room. The back area was simply bare walls and used as a general junk storage area. Above pics are after removing the dividing wall and cladding but before chucking out the old flooring.
Above pictures are after attaching timbers to wall and beginning to plasterboard. Also installed air conditioning condenser units onto the flat roof at the same time, didn't want to be dealing with any unexpected leaks after boarding the ceiling!
Plasterboarding almost complete at this stage with the exception of the ceiling, and most of the electrical and data cables have been run.
Sadly my plastering skills leave a lot to be desired, it took a far bit of sanding to bring everything to an acceptable finish ready for painting.
Didn't get chance to take any more pictures between plastering and the finished product. All the electrics are connected, racks have been fixed to walls, alarm fitted, ceiling and walls painted, coving fixed and painted, new laminate flooring laid and skirting attached to walls and painted. The room is still in need of an internal door and a new external door, but that is on hold for the time being due to some major work in the garden!
