Offset rear flue on heat-only boiler?
9 Oct 2019
Hi, new to this forum so apologies if this is a topic that has been covered previously. I have been asked to replace a Baxi Solo WM 40/4 powered flue HO boiler...quite an old machine. Very small, and installed in a kitchen cupboard. Its in-case rear flue is offset to the left (looking from the front) - the only way I'll be able to fit the new boiler in the same cupboard will be to find a small machine with a similar offset flue.
I've looked at Baxi 400 series, but it has a central flue, and Vaillant/Glowworm has an offset, but offset to the RIGHT, which exacerbates the problem.
Anyone know of a heat-only machine (don't need anything stronger than 20kw) with a left-hand offset in-case rear flue?
Nope. Just un stitch the bricks outside put new bricks in. then core out another hole. easiest and probably only solution
