Oil based MASTIC; recommendations
15 Feb 2008
Hello - very grateful of some advice please.
I need to re-point the mastic between the concrete sections of a pre-fab (Compton) garage.
My understanding is that they were installed using ‘BEVAMASTIC’ - an ‘Oil-based general purpose polymer reinforced construction sealant’.
This doesn’t seem to be widely available retail - I can source it directly but min order is 24 x 380ml tubes at >£85.
https://www.hodgsondirect.com/product-range/mastics/bevamastic/https://www.hodgsondirect.com/wp-content/uploads/2016/12/Bevamastic-PDS.pdf
My question - can anyone recommend something more readily available.
I have had a look and the only thing I’ve found is ‘EVERFLEX 115’
https://res.cloudinary.com/diq3xoeg...ants/EVERFLEX_115_GP_Building_Mastic_V1.1.pdf
Would this be an equivalent?
Thanks D
https://res.cloudinary.com/diq3xoegw/image/upload/v1628238199/Datasheets/Sealants/Building Sealants/EVERFLEX_115_GP_Building_Mastic_V1.1.pdf
Thanks D
The best flexible construction sealant is polysulphide mastic.
