oil boiler cycling
30 Dec 2009
Suffolk
i have a worcester bosch boiler, starts perfectly, but cycles on/off all the time! any ideas? changed pump, old pump needle pulsed at 120psi, new one is stable but still cycles, reduced air intake and this has helped a little.
What do you mean by cycles on and off all the time?
What were you hoping to achieve by upsetting the combustion air settings?
Do you mean that the burner is running, then cuts out, then relights without going to lockout?
This sounds to be a lack of air problem, maybe caused by the boiler being sooted up....adjusting things without a smoke test and gas analysis could give further problems.
Which boiler is it?
John :)
