- Joined
- 17 Sep 2004
- Messages
- 465
- Reaction score
- 10
- Country
I've had a Eurocal Turco 2000 70/90 oil boiler for about 8 years.
Throughout that time it has had the intermittant fault of cutting out. It generally restarts when you press the re-set button, but occassionally you have to wait a half-hour or so.
For the last 4-5 years the same OFTEC engineer has serviced it, including a couple of extra one-off visits to look at this problem specifically, and normally after his visit things improve. Until it recurs.
He has changed the nozzle size to a smaller one, but thinks the problem is to do with overheating, hence it cuts out when it gets too hot and does not always immediately re-start if it's been running for a while.
Before I call him out again, has anyone any suggestions? Or should I try a different engineer?
