Noticed I have no hot water and the boiler wasn't firing up, lockout light was on, pressed the button and it came on for a bit before going off again.
Had a closer look and noticed the clear final bit of the oil supply line was empty.
Tank claims to be half full (metal and can't see inside) so tried bleeding the oil pump with the bleed nipple and got the supply line full of oil and it seemed to fire up ok, but when the nipples closed, it just fills with air and cuts out and you can see the bubbles coming up from the tank side of the line into the clear bit.
From a quick look online I'm guessing I've got a bad seal or something and the pump is pulling the air in that way instead of oil?
I've got a service booked in two weeks time which I guess needs to become a repair, but I'm reasonably handy (not that you'd get that from my description so far!) and am happy to have a go if it's something DIYable...
Boiler is an HRM Wallstar 20/25 (2003 I think).
The oil tank is probably original to the house (late 80's...)
Any thoughts?
Any thoughts?
