For a few weeks now I've been having problems with an oil-fired Heatslave 15/19 locking-out intermittently. The problem lies with the burner not igniting and going into lockout. Having it serviced/nozzle changed and thoroughly checked has failed to cure it but when it was proving particularly stubborn to reset at the weekend I watched the control box go through its operating sequence. I noticed that the contact bar at the top of the control box moved slowly along, engaging the contacts to bring in the motor and solenoid then pausing for a second before moving one last bit to engage the final contact and ignite the burner. When this happens the burner lights, stays lit and the boiler operates perfectly. But sometimes the contact bar reaches the pause position then fails to move further to complete ignition, and the burner enters it's lockout state.
Naturally I assumed the control box was at fault and yesterday fitted a replacement, but the exact same thing is happening, although not so often and it now resets first time.
Now I'm left scratching my head. Any ideas anyone???
