Apologies if this is not the right place to ask this, but it's my first time, so here goes....
I own a large bungalow, and am currently converting our kitchen to a kitchen diner, by combining it with the dining room. In the kitchen sits a Firebird S 85/115 Oil Boiler with conventional flu, connected into the chimney stack though the wall behind it. The boiler was originally surrounded by a brick built cupboard, but I knocked it down in a wild sledge hammer moment.
My problem is that the boiler is very noisy, and (re-)building a soundproof surround would impact the space we have created, as it is located in the middle of a wall. Ideally, it would be hidden undercounter, and quiet.
I am told by Firebird that converting the boiler to balanced flu would dramatically reduce the noise, but from what I have read, this could not use the chimney stack, so the boiler would need to be moved against an outside wall ?
So my questions...
1) Is it worth upgrading & moving the boiler and installing a new flu that is approx 6 - 7 years old ? I have had wildly varying, four figure quotes for this work..
2) Is there any way a balanced flu conversion could use the existing chimney stack ?
3) Will a balanced flu conversion really reduce the noise that much ?
4) If I have to pay for moving the boiler and installing a new flu through the roof, should I consider buying a replacement condensing boiler that might pay for itself over time though oil efficiency ?
Any comments would be warmly received !!
So my questions...
