- Joined
- 20 Jan 2024
- Messages
- 5
- Reaction score
- 0
- Country
This is partly a DIY question in that I’d like to try and pinpoint the issue before reaching out to a professional.
We have an old open vented oil heating system, with 2 tanks in the loft. There’s no thermostat and you can’t heat the water in the hot water tank without also having the central heating/radiators on other than the immersion - so it’s basically all or nothing. The hot water tank and the radiator (both in the upstairs bathroom) are stone cold - the other upstairs radiators are fine and so are the downstairs radiators although a couple are a lot hotter than usual.
We also have a back boiler behind the coal fire with its own pump but this is also failing to give any heat to the bathroom radiator and hot water tank
Any ideas what the possible cause of this fault is?
I’m leaning towards there being a blockage of some sort. Because of the age of this system and the fact you can’t have hot water and central heating working independently I don’t think this is a case of a faulty diverter valve as I don’t think it has one, there nothing next to the hot water tank other than pipes.
