Hi
I have a 14 year old Myson Velaire Vitesse Oil boiler located downstairs which heats HW & CH. The boiler was serviced about a year ago. Upstairs is the hot water tank, water pump and two motorised valves. In the loft is the header tank. I have 15 radiators in the house all with TRV's. There is no thermostat (that i'm aware of)
In the morning everything comes on as programmed (CH should be on during the whole day), but after about an hour the boiler turns off and the radiators downstairs start to get cold. However the water pump doesn't switch off. The radiators upstairs stay warm for quite a few hours even though the boiler is off. The house gets colder and colder and but the boiler won't turn back on. In the end I manually turn the programmer to off and the water pump shuts down. Once everything seems cool I can turn the programmer on again and the boiler starts up with about a 50% chance to continue the cycle described above.
I checked the motorised valves and they appear to be functioning i.e. they are opening and closing.
Any ideas??
Any ideas??
