Hi all, ive a couple of problems with the oil boiler.
Its a GRANT Vortex Combi 26.
I decided to fire things up and check everything is working ok prior to the winter. I first of all notice that 4 out of th 6 rads upstairs were only getting warm half way so decided to bleed them.
System preasure dropped to near nothng after i had done one, so thought id top up the system. Sounds straight forward... if only.
I opened up the "Shut Off" valve first then topped the preasure by opening slowly the "Double Check" valve.. all going ok. All rads now bled and nice and hot. Unfortunatly the "Shut off valve has been faulty in the past and seems to have been gunked up with silicone. It now has a very small drip coming from the valve body, and it drips onto the main burner.. Arghhh! looking deeper there is evidence that this has been doing this before and for a while. I could just silicone up, but would rather do a propper job.
Any advice on repairing the valve?
Secondly there is a flexi vent tube from the burner, this was not even connected properly to the burner, only half on, ive now fixed in place with clip fastner, could this of been left half on to cover up another problem? just asking in advance?
Also after looking outside the pipe work has a leak around the fire shut off valve... whats best way to seal these up? It does look like someones had a go already!!!!
See pictures:
Im letting the system settle over night and cool before i check the preasure again. Ive managed to get a piece of pipe in to catch the drip and divert it into a bowl keeping it away from the burner.
Can I fix these problems myself, or do I need to get a plumber in who is oftec registered?
Thanks in advace
M.A.
See pictures:
Thanks in advace
M.A.
