Hi all,
Just moved to a house with an ancient Grant oil boiler supplying a hot water tank and the heating, via a Danfoss timer connected to a thermostat in the hallway for the heating, and one in the tank for hot water.
Everything appears to be in working order, except the heating keeps coming on even when it's set to be off.
It heats the radiators and hot water fine when it's set to be on, but also comes on intermittently throughout the day.
I've tried turning the thermostat way down, didn't make a difference. I've tried manuall setting the heating and hot water to "off" on the Danfoss controller and it still fires up.
I've tried to find evidence of a frost thermostat in the boiler or somewhere in the house (as the weather's been chilly) but couldn't find one, it's 12 degrees outside right now and the boiler is indoors so I don't think it's that.
I suspect the A/B valves controlling whether the water goes to the hot water tank or the radiators may be broken, but I don't think that could cause it to fire up even when both are set to off?
Anyone got any ideas? Any input much appreciated.
